Discussion topic: Hi. My sky q mini boxes aren’t connecting and I have no viewing apart from the main box
This message was authored by: Ally262
Can you please help with our Wi-do collection
Re: Hi. My sky q mini boxes aren’t connecting and I have no viewing apart from the main box
Hi @Ally262
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
