13 Feb 2024 10:10 PM
Sky Q not rewinding programmes, also getting instead of pausing.
I am unable to delete recordings.
I have re booted and plugged put box and still same
I like to be able to record programmes
Please help
13 Feb 2024 10:22 PM
Please help
Hi @Teresa131
Please help
Hi @Teresa131
13 Feb 2024 10:41 PM
Hi Old fella
I tried all your instructions and it worked! I can delete, record and pause..Thank you so much. I would never ever have managed that myself
