Discussion topic: Hi I moved houses and in The house, I came to the socket on the wall that connects Sky Q is not
Message posted on 18 Jun 2024 01:58 PM
I moved houses in February 16, 2024, and the house I came to did not have a wifi socket, the other issue is the socket on the wall that connects Sky Q does not work at all can anyone help, please thanks
Message posted on 18 Jun 2024 02:11 PM
Re: Hi I moved houses and in The house, I came to the socket on the wall that connects Sky Q is not
@Pee1 wrote:I moved houses in February 16, 2024, and the house I came to did not have a wifi socket, the other issue is the socket on the wall that connects Sky Q does not work at all can anyone help, please thanks
What do you mean by a WiFi socket? Do you have broadband at your new house?
Also, what is the socket that connects Sky Q? Is your Sky Q system working? Is the box connected to a satellite dish?
Message posted on 18 Jun 2024 02:19 PM - last edited: 18 Jun 2024 02:20 PM
Ideally you'd have booked a Home Move through Sky well before before relocating: that way they sort out the satellite signal and broadband connection.
Broadband doesn't follow an ISP router around the national network: it must be specifically provisioned by the ISP at the address.
Sky Q cannot work through a satellite dish previously used for Sky+ until the dish is modified.
Have you been without both services for four months?
Message posted on 18 Jun 2024 03:39 PM
Yes I have been without both service for four months until now as we speak
Message posted on 18 Jun 2024 03:52 PM
@Pee1 wrote:Yes I have been without both service for four months until now as we speak
Did you ever tell Sky before you moved? (Or even after)
