06 Apr 2024 09:09 PM
Hi, I cannot connect Sky q to community fibre- I enter my password and it won’t connect
can someone help- it's infuriating
06 Apr 2024 09:20 PM
Hi @Haley1
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
24 Oct 2024 09:56 AM
I keep getting the same thing. No idea why - but it's been fine all spring & summer, but lately it's a case of unplugging all the broadband equipment & the sky Q box then allowing the community Fibre to reboot, then the sky Q box and going to the setup virtually everyday.
No idea why it's happening now, and so frequently when everything else connects to the broadband equipment fine! Maybe one of the two needs a software update possibly???
26 Oct 2024 12:50 PM
I'm using Community Fibre broadband and have a Sky Q box. For all of the Spring, Summer etc up until this month (October) it's been fine connecting to the WiFi.
Now, every day for the last fortnight when the box is in standby overnight, it always loses connection to the WiFi (or rather it knows it's there, has one tick for the router and a cross for the internet) - even though every other device connects without fail.
The only way around it is unplug all the router equipment and Sky Q box plug everything back on and one its all booted up, behold - it suddenly connects after setting up the WiFi password etc on the box again!!
This is incredibly annoying and is a major pain in the backside!!
Anyone have any suggestions?!!
Thanks, Andrew.
26 Oct 2024 01:26 PM - last edited: 26 Oct 2024 01:28 PM
Posted by a Superuser, not a Sky employee. Find out more@andrewmw Your post has been moved to the correct forum, your issue has niothing to do with Sky Glass where you aded this post to
In addition you already raised the issue in this thread where your latest post has been moved to.
11 Nov 2024 08:42 PM
Where is the correct forum...I'm having same issue as other user.
