8
This discussion topic has been answered Discussion topic: Hey,how can i update my TV model on the settings of my Remote in order to control both my box and TV
This message was authored by: Kizito
Please can anyone help on how i can update my TV model on the list for me to be able to control my box and TV with the same remote.(My TV model is not available on the Sky list)?
Many thanks
This message was authored by: Laing1 Answer
Re: Hey,how can i update my TV model on the settings of my Remote in order to control both my box an
@Kizito wrote:
It's a Samsung UE70BU8000K.
Thanks for getting in touchplease.Appreciated.
Many thanks.
@Kizito  after entering UE70 did you click on the option my model is not listed then try the setting it shows ie 1 of 8 so 8 settings to try
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Many thanks
@Kizito what TV make and model do you have ? as only Sky can update the list that comes up
Avatar for Kizito
Many thanks.
Many thanks.
Avatar for Kizito
Thanx buddy,
It's now working.Am so grateful.
Regards
@Kizito wrote:
Thanx buddy,
Regards
@Kizito glad you got it sorted
Avatar for Kizito
@Laing1 @How do i activate my Netflix on my phone.
Have tried to login and it's says that I don't have an account of which am using it on my TV?
Many thanks
Many thanks
@Kizito Sorry only just seen this To use netflix on your phone you should just login with the username and password that you  setup and used for your Q box
This message was authored by: ClaireR78
I have just bought an RCA tv for my daughter. The model wasn't listed so I clicked find it for me. It came up with 1 out of 37. I found 2 that worked the volume but will not turn the tv on or off. Can anyone please help
