Discussion topic: Help when frozen screen says no signal
Message posted on 21 Feb 2025 04:04 PM
Can someone please help me My tv screen says on No signal. It is on correct setting when Iook to source. Checked cables. The help line is no good as it just takes.me to check connection and all is fine and that's where on line help stops. I think there is a short number you can ring but I can't remember it. Any other help number known where you speak to someone please.
Message posted on 21 Feb 2025 04:32 PM
Re: Help when frozen screen says no signal
@DeeJam Using your Sky remote after switching on your Q box try the buttons Home1080Home
Ths should reset the output of your Q box to 1080.
Message posted on 21 Feb 2025 07:25 PM
Thank you. It has resolved but I will remember Home1080Home another time.
Message posted on 22 Feb 2025 10:12 AM
The short number is 150 if you have a Sky phone contract.
