This discussion topic has been answered Discussion topic: Help hdmi resloution of sky not compatible
Message posted on 20 Mar 2023 10:39 AM
We have bought a new TV. When on hdmi source it states resolution not compatible to external device and will not find sky.
Message posted on 20 Mar 2023 12:00 PM - last edited: 20 Mar 2023 12:09 PM
Hi @Niki76 Are you using the short HDMI lead that came with Sky Q box? If not what is the speed and length of your cable?
Message posted on 20 Mar 2023 10:43 AM
Re: Help hdmi resloution of sky not compatible
Hi @Niki76 Try resetting your Sky Q box to 1080i. Point your Sky Q remote at the box and key in the sequence Home 1 0 8 0 Home
Message posted on 20 Mar 2023 10:58 AM
Tried this so many times it does nothing sadly. Just have hdmi not supported resolution not supported change external device resolution. @MightyQuinn
Message posted on 20 Mar 2023 11:01 AM
What is the TV?
Almost all new TV's should support any resolution the Sky box would throw at it.
Message posted on 20 Mar 2023 11:06 AM
Hi @Niki76 To rule out a problem with your new TV, if you still have the old one then connect it and set the resolution of the Sky Q box to it's lowest setting 576p.
Message posted on 20 Mar 2023 11:12 AM
It's not the tv we took it back yesterday put new TV up and its doing the same. Had sky engineer put twice and of course it worked on the day. Its so frustrating. Its Samsung they struggled to help. @MightyQuinn
Message posted on 20 Mar 2023 11:55 AM
Try different HDMI lead? Or different input.
Message posted on 20 Mar 2023 12:01 PM
@MightyQuinn wrote:Hi @PandJ2020 Are you using the short HDMI lead that came with Sky Q box? If not what is the speed and length of your cable?
Not me - you mean @Niki76 😀
Message posted on 20 Mar 2023 12:09 PM
Message posted on 20 Mar 2023 12:37 PM
Changed lead 3 times sky gave a new one to try. So should work. @
Message posted on 20 Mar 2023 01:13 PM - last edited: 20 Mar 2023 01:13 PM
What TV is it? (Samsung make a LOT of TVs)
Are you using a OneConnect box?
Message posted on 20 Mar 2023 01:24 PM
- Crystal 8000 HD tv
Message posted on 20 Mar 2023 02:29 PM
Do you mean UHD?
Like the UE43BU8000? (43" version)
Doesn't seem to come with the OneConnect box so that can't be the problem.
