Discussion topic: Help! Technical fault with this channel is being displayed.
This message was authored by: SueIsaac
Hi
Can anyone help?  No channels are working and 'there is a techical fault with this channel.  Please try later' is displayed.  Recordings won't work.  Apps won't work.
Please can someone advise?
Many thanks!
Re: Help! Technical fault with this channel is being displayed.
@SueIsaac wrote:
Hi
Many thanks!
Hi @SueIsaac
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
