Discussion topic: Help! Technical fault with this channel is being displayed.
This message was authored by: SueIsaac
Message posted on 18 Aug 2023 09:48 PM
Hi
Can anyone help? No channels are working and 'there is a techical fault with this channel. Please try later' is displayed. Recordings won't work. Apps won't work.
Please can someone advise?
Many thanks!
Find out more
Message posted on 18 Aug 2023 09:50 PM
Re: Help! Technical fault with this channel is being displayed.
@SueIsaac wrote:
Hi
Many thanks!
Hi @SueIsaac
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
