Discussion topic: Hello, we are experiencing missing channels? For instance we have no BBC2 or ITV4 says satellite iss
This message was authored by: RDG54
We are not able to watch certain channels it says we have a satellite issue? However other channels are working fine?
Re: Hello, we are experiencing missing channels? For instance we have no BBC2 or ITV4 says satellite
@RDG54 your dish may be misaligned you'd need to contact Sky to get an engineer out
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@RDG54
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
