8
This discussion topic has been answered Discussion topic: Hello neither of my sky mini boxes will show the Sky channels. My main box is working perfectly. I’
This message was authored by: TonyP07
Hello neither of my sky mini boxes will show the Sky channels. My main box is working perfectly. I’ve turned off both an reset them. Rebooted my router and updated the software but still no joy
Avatar for TonyP07
This message was authored by: TonyP07 Answer
Re: Hello neither of my sky mini boxes will show the Sky channels. My main box is working perfectly
I've done the reset and now I can't get some Sky channels on my main Q box. I can get SkySp PL HD but not any other spots channels. Movies are fine.
it's getting annoying now.
Hi @TonyP07
Reboot the minis as above.
Avatar for TonyP07
Cheers, I'll give that a try.
Avatar for TonyP07
Still no joy.
the mini box says no satellite signal but it doesn't get a direct feed from the dish does it?
Avatar for TonyP07
Whoops, I haven't done the mini box reboot yet.
Avatar for TonyP07
Mini box reboot but no joy.
Hi @TonyP07
Try a Reset Settings in the main Q box hidden menu.
When the main box is back up and running reboot the minis again
Avatar for TonyP07
Thanks for this, will give it a shot later.
Avatar for TonyP07
