2
This discussion topic has been answered Discussion topic: Hello does anyone know how many Sky Q boxes can I have in my house?
This message was authored by: Theo23
Hello
does anyone know how many sky q boxes can I have in my house?
thanks
Re: Hello does anyone know how many Sky Q boxes can I have in my house?
@Theo23 wrote:
Hello
thanks
@Theo23
One main box only. You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
@Theo23 wrote:
Hello
thanks
@Theo23
Avatar for Theo23
Thanks for your answer Daniel 0210
