Discussion topic: Hello can anyone help it says I have no network connection
Message posted on 30 Oct 2023 12:41 PM
can anyone help I called last week and got cut off and couldn't go through the farce again it saying I have no network I've tried all instructions and still nothing I have a sky q box thank you
Message posted on 30 Oct 2023 12:43 PM
Re: Hello can anyone help it says I have no network connection
Hi @Sam62
Have you carried out a Network reset exactly as follows?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 30 Oct 2023 12:45 PM
Yes I have and still brings me back to unsuccessful connection same with my mini box
Message posted on 30 Oct 2023 12:50 PM
