Discussion topic: Hello - I have a Sky Q mini box which says it is connected to the main box but it’s showing ‘no sate
This message was authored by: Hiero12
I've checked settings in both boxes but still won't work. Main room is ok but the Mini box has been playing up for a couple of weeks. It keeps losing its connection with the main one. I've not changed the positioning of the broadband router so any ideas out there please?
Re: Hello - I have a Sky Q mini box which says it is connected to the main box but it’s showing ‘no
Hi @Hiero12
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Hiero12
Thank you, I tried that sequence but same problem. I think It may be faulty main Sky Q bix as it seems to be having other malfunctions like can't get it to switch off, seems to be running very hot too.
Hi @Hiero12
