Discussion topic: Hello. I could not connect to Netflix at the main Sky box. I went to my front room to try the second
Message posted on 16 Aug 2024 06:44 PM
Hello. I could not connect to Netflix at the main Sky box. I went to my front room to try the secondary sky box. On starting a message said my card needed to be paired and to select the red button. I did so about 15 mins ago and the screen is blue. No messages. The other box appears to be off now. I tried switching it on by remote it did not work. Can you help please
Message posted on 16 Aug 2024 06:48 PM
Re: Hello. I could not connect to Netflix at the main Sky box. I went to my front room to try the se
Hi @john2924
Reboot the mini as above.
