Discussion topic: Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe!
This message was authored by spyro123 This message was authored by: spyro123
Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe! This is the second time this has happened. The first time I phoned and eventually someone answered and fixed it remotely. This time I was on the phone for 20 minutes and it's not been fixed!
Re: Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe!
Hi @spyro123
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
spyro123
@oldfella I've  just done that but unfortunately it's not worked.😢
Hi @spyro123
You could try a Reset Settings in the Q box hidden menu. Failing this I can escalate your post to Sky
spyro123
@oldfella i've done all that now but it's still not working😢😢
Hi @spyro123
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
spyro123
@oldfella @Thank you, really appreciate that.
This message was authored by Tom-W19 This message was authored by: Tom-W19
Posted by a Sky employee
Thanks for escalating. We've sent an invite to @spyro123.
Tom
