Discussion topic: Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe!
This message was authored by: spyro123
Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe! This is the second time this has happened. The first time I phoned and eventually someone answered and fixed it remotely. This time I was on the phone for 20 minutes and it's not been fixed!
Re: Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe!
Hi @spyro123
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for spyro123
@oldfella I've  just done that but unfortunately it's not worked.😢
Hi @spyro123
You could try a Reset Settings in the Q box hidden menu. Failing this I can escalate your post to Sky
Avatar for spyro123
@oldfella i've done all that now but it's still not working😢😢
Hi @spyro123
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
Avatar for spyro123
@oldfella @Thank you, really appreciate that.
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @spyro123.
Tom
Avatar for spyro123
Hello, I can’t watch sky cinema!
Hello, I can’t watch sky cinema although I subscribe to it. It tells me I need to subscribe! This is the third time this has happened and I can't face another lengthy call to sky with no results. Last time this was the only place I could get help.
Re: Hello, I can’t watch sky cinema!
@spyro123
I’ve escalated your post to Sky and the Messaging Team should contact you later today.
You need to watch out for a post from one of the team inviting you to a private chat and then you should see a blue/red speech bubble at the bottom of your forum page. You’ll have 48 hours to click on it and start the private chat or it will close automatically. If you fail to respond to a chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll need to check the chat thread fairly regularly.
This link explains what happens.
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to @spyro123 to chat.
Avatar for spyro123
Hello, I've not been contacted?
@spyro123
A chat invite was sent yesterday morning. Do you see a blue/red speech bubble at the bottom of your forum page? As previously stated you'll have 48 hours to click on it and start the private chat or it will close automatically. This link explains what happens.
Avatar for spyro123
Hello, unfortunately I've been very unwell and didnt responded in time...
@spyro123
If I re-escalate this are you going to be able to fully participate?
