Discussion topic: Havin problems with no signal on STV 103 and CH4 104, discovered STV and CH4 on 803 and 804
Message posted on 25 Jan 2024 10:08 AM
Message posted on 25 Jan 2024 11:23 AM
Re: Havin problems with no signal on STV 103 and CH4 104, discovered STV and CH4 on 803 and 804
@Juliew1
”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 30 Jan 2024 08:41 PM
Exactly same problem Julie. Only affects STV HD on 103 for us. Pretty sure isnt a dish issue as every other channel working absolutely fine. 803 ok. Suspect STV HD not given any decent bandwidth.
Message posted on 15 Mar 2024 01:49 PM
I am having the same problem as many others with regards STV/ITV breaking up or reading no signal. I have followed the (?) guidance, restarted the box but the issue remains. This seems to have been ongoing for several months.
When so many similar complaints have been made why has Sky not sorted the problem or at least advise viewers about the issue?
Any advice would be appreciated.
Message posted on 15 Mar 2024 01:51 PM
It's not a problem Sky can just fix. If it's a dish issue you need to follow the troubleshooting in the link in my earlier post and potentially book an engineer to check your dish.
