Discussion topic: Have wyrestorm 4 way splitter hdmi over ethernet with sky + box. Want replicate with sky q - what’s
Message posted on 31 Mar 2024 10:12 PM
Hi have wyrestorm 4 way hdmi over ethernet splitter /baluns with sky+ box. Works perfectly with it emotes in each room Thinking of changing to sky q or sky over fiber. What splitter system would work well ?
Message posted on 31 Mar 2024 10:13 PM
Re: Have wyrestorm 4 way splitter hdmi over ethernet with sky + box. Want replicate with sky q - wh
Should read 'ir remotes'
Message posted on 02 Apr 2024 08:56 AM
@warrenwb wrote:Hi have wyrestorm 4 way hdmi over ethernet splitter /baluns with sky+ box. Works perfectly with it emotes in each room Thinking of changing to sky q or sky over fiber. What splitter system would work well ?
Hi @warrenwb is there a reason why your current splitter system wouldn't work with Sky Q or Sky Stream?
Message posted on 02 Apr 2024 09:18 AM
Hi thanks very much your response- I am concerned if the technical output characteristics of the boxes are meaningfully different and will cause problems. Thinking particularly about HDCP type.
Message posted on 02 Apr 2024 09:19 AM
Also concerned about if /how remotes will work in the various rooms.
Message posted on 02 Apr 2024 10:44 AM
@warrenwb wrote:Hi thanks very much your response- I am concerned if the technical output characteristics of the boxes are meaningfully different and will cause problems. Thinking particularly about HDCP type.
Fair comment @warrenwb your current splitter system if it wasn't HDCP compliant wouldn't you get a message on your tv saying " HDCP is not supported on this screen"
Do you have the model number for the current splitter please so I can google the specifications
Message posted on 02 Apr 2024 02:33 PM
@warrenwb is this what you have
WyreStorm SP-0104-H2 4K60 1:4 HDMI Splitter
The splitter is fully HDCP 2.2 compliant
Message posted on 02 Apr 2024 02:52 PM
Thanks - I have Wyrestorm MX-0404-QI
Message posted on 02 Apr 2024 05:03 PM
@warrenwb wrote:Thanks - I have Wyrestorm MX-0404-QI
Thanks for that @warrenwb looking at the specs for your splitter it supports HDCP but no version number
Also this may help Sky Q boxes specs
https://www.sky.com/help/articles/sky-q-box-specs
Also look for the HDMI versions for the different Sky Q boxes.
Message posted on 02 Apr 2024 05:42 PM
Thanks. As it's an old model suspect it won't support HDCP 2.2 - I think I will change to a newer device - thinking of the FOURKAY range / extender - don't need the matrix anymore. Do you have any feedback / knowledge of FOURKAY kit ?
