Discussion topic: Have wifi but no sky tv. Not even the sky screen and q box on amber
Message posted on 19 Sep 2023 07:47 PM
I still have connection to wifi but no sky. Usually if it drops a signal I still have the sky screen but nothing. The box is on permanent amber. I have tried all the steps they recommend and nothing is working
Message posted on 19 Sep 2023 07:54 PM
Re: Have wifi but no sky tv. Not even the sky screen and q box on amber
Hi @Louise772
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 19 Sep 2023 08:27 PM
@Louise772 wrote:I still have connection to wifi but no sky. Usually if it drops a signal I still have the sky screen but nothing. The box is on permanent amber. I have tried all the steps they recommend and nothing is working
Thanks for the info. I have tried what you said and now I have a green light on the box but a message saying you need satellite connection. So is this the dish or the telephone wire? Thanks
Message posted on 19 Sep 2023 08:32 PM
Hi @Louise772
Thats the Dish connection.
Work through the following link and if you cannot solve your issue it will lead to booking an Engineer.
Message posted on 19 Sep 2023 08:55 PM
Ok thanks
