Discussion topic: Have to disconnect sky q box to watch recordings and catch up
Message posted on 28 Dec 2023 12:25 PM
I have to unplug my sky q box to watch recordings, catch up tv. Sometimes recordings have failed
Message posted on 28 Dec 2023 12:43 PM
Re: Have to disconnect sky q box to watch recordings and catch up
Message posted on 28 Dec 2023 12:52 PM
Thank you I will try it
