This discussion topic has been answered Discussion topic: Have a sky q mini box which has been connected to tv in bedroom for 5+ years have recently had a new
Message posted on 21 Jun 2023 11:45 AM
Have had a sky q mini box connected to to in bedroom for 5 + years have recently had a new router and now mini box won't work
Message posted on 21 Jun 2023 12:04 PM
Hi @Ico001
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically ).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. Make sure you press the WPS button on the Sky router and not the reset button.
Hi @Ico001
Message posted on 21 Jun 2023 12:25 PM
Re: Have a sky q mini box which has been connected to tv in bedroom for 5+ years have recently had a
Thank you very much for the advice. We're up and working at last .👏🏻👏🏻
