2
This discussion topic has been answered Discussion topic: Have a new sky q box and it won’t let me click on the wi fi connection page. Please help
This message was authored by: angrypete
New sky q box won't let me click on the Use a different wi fi connection screen. How do we fix this please?
Re: Have a new sky q box and it won’t let me click on the wi fi connection page. Please help
Hi @angrypete
Reset your Q box remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the setup issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Hi @angrypete
Avatar for angrypete
Thank you this has done the trick.
