Discussion topic: Has my Sky Q box broken down?
This message was authored by: Sewingforfun
For about the 4th time now the TV suddenly goes blank, the Q on the box starts to flash very slowly (eventually stops), the little light on the box goes orange and I've pressed the reset button which is now flashing but nothing is coming back.   I've also turned it off at the plugs and waited a few inutes before turning back on again.   I think the last 3 times it has come back on without my intervention but not really sure.   Do you think my Q box has broken or could it be the TV?   Any help appreciated, thanks...
Re: Has my Sky Q box broken down?
Hi @Sewingforfun
Try a Reset Settings in the Q box hidden menu.   See if that helps.
Avatar for Sewingforfun
Thank you so much for your reply.   I'm not sure I'm competent enough to do all this but anyway I can't do it because the Q box or TV won't come on (or can it be done from the mini box upstairs because that is working fine?).
Hi @Sewingforfun
No it must be on the main box.
When you say you pressed the reset button - which was this ?
If it's was flashing it looks like it was the WPS button
I think it was the WPS button!
I will call Sky in the morning - thank you for your advice, much appreciated...
