Discussion topic: Hard reboot done today and still issues !!
This message was authored by: NikkiG12
I had to have a customer service agent help today as all 3 of my mini boxes weren't working. Was expecting this to work especially as I had to lose all my recordings.
the three mini boxes now have intermittent connectivity issues which is really frustrating as the screen goes blank at least once a minute.
on top of that I have tried to download some of the programmes I know had been deleted and I have an error message saying ' there is a technical fault ' and nothing will download.
Should I request a new sky q box ? As it's clearly not doing what it should do ?
Re: Hard reboot done today and still issues !!
Hi @NikkiG12
Try reconnecting all boxes.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
