04 Dec 2023 09:47 PM
Hi , had an engineer come today to fix my broadband but now my mini boxes won't connect?
04 Dec 2023 09:51 PM
Hi @Simon196
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the mini. Start with the one nearest to your Q box.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. You can also use a mini if nearer and already connected.
04 Dec 2023 09:55 PM
Hi , thanks I've tried that , it has been working fine up until today when he has been , he was fixing broadband so I have no idea why suddenly I've got this problem , worked before ?
04 Dec 2023 10:18 PM
I'm embarrassed to say I was pressing the wrong button , it's working now , thank you
