Discussion topic: Green light on SkyQ but TV says no signal
Message posted on 08 Jul 2024 09:29 AM
We have replaced SkyQ box. We have no HDMI cables. SkyQ box shows green light. TV says no signal. We have tried different Inputs HDMI1 HDMI2 for example.
Message posted on 08 Jul 2024 09:31 AM
Re: Green light on SkyQ but TV says no signal
That should say NEW not no HDMI.cables
Message posted on 08 Jul 2024 10:16 AM
@Dellburt wrote:
TV says no signal.
@Dellburt
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
Message posted on 08 Jul 2024 10:45 AM
Hi @Dellburt
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
