Discussion topic: Got sky multi screen. just added sky premiership. now multi screen doesn't work. not happy.
This message was authored by: WestHam15
Got my multi screen a few weeks back . son set it up working fine. Just added sky premiership doesn't work. tried calling and got the robot who promised to send me a text to help me. After 2 calls nothing. NOT HAPPY WITH LACK OF SUPPORT
Re: Got sky multi screen. just added sky premiership. now multi screen doesn't work. not happy.
Hi @WestHam15
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
