Discussion topic: Got new sky q box,now some channels are not as clear as was on old Q box
This message was authored by: David1609
Re: Got new sky q box,now some channels are not as clear as was on old Q box
@David1609  I'm nmot sure why your're tagging a fellow customer for this query?
Have you gone into the Sky Q setting menu and checked the picture settings are 1080i?
Avatar for David1609
He's tried to tag me as the Mrs!
Basically, we had a hard drive error come up on old Sky Q box and so Sky sent new one, self install. Everything connected exactly the same as before but now any SD channels, especially Sky Sports News that were previously crystal clear are fuzzy and any writing is blurry / shadowing. Pictures, particularly moving players etc are pixilated.
HD channels are fine as is the guide.
Checked settings and same on 1080p or 1080i.
Very frustrating as picture is rubbish where before we had no problems (until hardware issue).
Any ideas?
Hi @David1609
What size is your TV and is it 4K?
Sony Bravia 46" and not 4k.
Understand it'll have limited capabilities but it's frustrating as old box was fine!
Hi @David1609
As I'm sure you are aware HD is 4 times the resolution of SD and so there is going to be 4 fold increase in detail in HD.  This is very noticeable on screen text.
Just to confirm it's not a setting on your Q box first make sure the Q box is on the latest software version.
https://www.sky.com/help/articles/sky-software-updates
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.  If your Software does need updating see the help link below.
https://www.sky.com/help/articles/updating-sky-box-software
once you are sure the Sofware is the latest try a Reset Settings in the Q box hidden menu.
