Discussion topic: Got a new router and the password doesn’t work to connect to wifi
This message was authored by: Tony134
Re: Got a new router and the password doesn’t work to connect to wifi
Hi @Tony134
Avatar for Tony134
@oldfella Thanks for your reply, The problem was , the password on the router was incorrect, the last letter written as an "L" was actually a capital i, sky chat quickly resolved it once i got to speak to a human. thanks again.
This message was authored by: Dirkhome
Had the same problem. Check the password on the back of the modem instead of the printed card in the box. On the back of the modem it is more clear which letters are capital i.  Mine looked like lower case l
