This discussion topic has been answered Discussion topic: Gold HD briefly loosing signal 18/07
Message posted on
18 Jul 2024
09:33 PM
- last edited:
19 Jul 2024
09:50 AM
by
Daniel-F
Gold+1 keeps briefly losing signal tonight, screen goes black then pic comes back, anyone else?
Message posted on 25 Jul 2024 02:36 PM
Hi all,
Thanks everyone for confirming the issue with Gold HD from over the weekend.
We had this checked and the issue cause has been identified and looks to be fixed from our end now.
If anyone is still experiencing the issue with Gold HD however please do reach back out and confirm 🙂
Thanks,
Community Moderator
Message posted on 18 Jul 2024 09:51 PM
Re: Anyone having this problem with HD GOLD
There are no +1 channels on Glass or Stream. So I assume you have Sky Q which is a totally different method of delivery (via satellite rather than broadband).
MikeAlanR
Message posted on 18 Jul 2024 10:10 PM - last edited: 18 Jul 2024 10:12 PM
Re: Gold+1
I've not noticed it myself as I haven't been watching that channel, but I have seen some comments about the UKTV channels including Gold dropping out and going blank today on all platforms, so it may be related to that.
Message posted on 19 Jul 2024 12:58 AM - last edited: 19 Jul 2024 01:02 AM
@Annabel+L Your post has been moved from a thread you added to in the Glass section as Glass/Stream has no +1 channels so is not relevant to that particular platform.
Your duplicate thread has also been removed.
Message posted on 19 Jul 2024 07:26 PM
Re: Gold HD briefly loosing signal 18/07
Yes Sky Gold keeps dropping out, think I need a refund!
Message posted on 19 Jul 2024 07:33 PM
Gold is part of the UKTV group (not Sky) and their channels have been having intermittent issues for a few days.
Message posted on 21 Jul 2024 11:51 AM
Same here. Must be a UKTV problem.
I don’t work for Sky.
If I have helped then please leave a like.
Hi all,
Thanks,
Community Moderator
Message posted on 26 Aug 2024 08:48 AM
I seem to have lost Gold HD as it comes up with a signal issue on my Sky Q box / dish ??
Any fixes out there ??
Message posted on 26 Aug 2024 08:51 AM
@NDG+1
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 26 Aug 2024 08:56 AM
Thank you for the update, interesting that Gold +1 works fine and there does not appear to be any other channels that are not working.
