This discussion topic has been answered Discussion topic: Getting Sky Q - does it need an ethernet connection to the internet or can it work on wifi?
Message posted on 30 Mar 2025 07:39 PM
I had Sky Stream, and have decided to move to Sky Q; Sky Stream was unreliable and glitchy and not really fit for purpose for me - the menu is annoying too. My router is in a different part of the house to where the TV is and am wondering if this will be an issue - do you know if the Sky Q box needs to be connected to the internet via an ethernet cable or can it work on wifi?
Many thanks!
Message posted on 30 Mar 2025 07:43 PM - last edited: 30 Mar 2025 07:44 PM
Many thanks!
hi @Newbie998
Yes SKY Q can connect via wifi - probably the majority of customers use wifi
It does, of course, need to have a cable from the dish
Many thanks!
hi @Newbie998
Message posted on 30 Mar 2025 08:40 PM
Re: Getting Sky Q - does it need an ethernet connection to the internet or can it work on wifi?
I would search this forum for "wifi" or "connection" or "router" to get a sense of its reliability over wifi.
Message posted on 30 Mar 2025 08:51 PM
However, bear in mind that the forums are always biased towards any customers that have problems and do not reflect the majority that don't
Message posted on 30 Mar 2025 10:16 PM
And all the other forums they go to.
My firmly held belief, having worked for big IT vendors for a couple of decades, is that the wifi networking in the Q box is a proprietary dog's breakfast, hacked to solve the wifi performance challenges of 2010, which just about behaves itself in ideal conditions with a Sky (pre-Max) router.
I'd love to see real data on the % of customers who have problems with wifi.
powerlines or ethernet on the other hand, I think work well enough. You can get it stable.
