This discussion topic has been answered Discussion topic: GB News Channel Skyq
Message posted on 16 Jun 2024 10:11 PM
Whats happened to channel 512(GBNews)? It seems to have gone SD.
I have just had new Skyq box installed and every HD channel is working perfectly, except 512.
Has anything changed with their broadcasts? anyone else have this problem?
Message posted on 17 Jun 2024 10:19 AM
For your information GB News is one of the weaker channels broadcasting in the UK, along with CNN & Bloomberg (and possibly Al Jazeera). They use a different a European wide beam rather than the normal UK/ROI transponder.
These channels will likely be one of the first to be affected if your satellite dish is slightly out of alignment which won't be visible to the naked eye so you could see if you can watch those.
Message posted on 16 Jun 2024 10:28 PM
Re: GB News Channel Skyq
There was a change late last year which makes a slight dish misalignment more likely to cause signal loss in the UK
https://rxtvinfo.com/2023/gb-news-sat-switch-improves-european-reception/
Message posted on 17 Jun 2024 10:14 AM
Oh Well. No great loss.
I just wondered if it was the new box that's just been installed. As wasn't an issue with the old one.
Thanks for the info.
Message posted on 17 Jun 2024 10:52 AM
I have checked and they are all as before. It really is only channel 512.
Message posted on 18 Jun 2024 02:57 PM
Why is GB news not available today?
GB News is not available today, does anyone know why?
Message posted on 18 Jun 2024 03:02 PM
Re: Why is GB news not available today?
@Julie0905 I have merged your post to this existing thread that is discussing the same issue.
Message posted on 18 Jun 2024 05:47 PM
@Julie0905 wrote:GB News is not available today, does anyone know why?
Working fine here, in the middle of a thunderstorm too.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 28 Jun 2024 09:11 PM
Clearly, sky have blocked GB News, which is absolutely utterly despicable
Message posted on 28 Jun 2024 09:39 PM
GB News has not been blocked and is still available
As the Post now marked as an Answer GB News uses a transponder that is weaker in the UK so any slight mis-alignement wil cause the channel to either pixelate or even for some show as not availble
Message posted on 28 Jun 2024 09:59 PM
@Stellak wrote:Clearly, sky have blocked GB News, which is absolutely utterly despicable
Completely untrue. Though if it were, I'd have a lot more respect for Sky.
Message posted on 28 Jun 2024 11:49 PM - last edited: 28 Jun 2024 11:49 PM
Clearly they haven't, as already mentioned within this thread it's likely your dish is slightly misaligned.
Message posted on 29 Jun 2024 09:29 AM - last edited: 29 Jun 2024 09:36 AM
And simply isn't happening.
The last 'block' was when RT was removed from broadcast across Europe: such things do tend to get noticed and attract wide media attention.
https://www.bbc.co.uk/news/entertainment-arts-60584092
It's worth noting that the transponder change which weakened UK signal was absolutely the choice of the GB News owners to favour (ironically) their audience in mainland Europe .
Message posted on 09 Aug 2024 07:54 AM
Re: GB News
GB news is difficult to get and as far as Al Jazeera its accessible . What is the problem please
Message posted on 09 Aug 2024 08:02 AM
Re: GB News
