16 Jun 2024 10:11 PM
Whats happened to channel 512(GBNews)? It seems to have gone SD.
I have just had new Skyq box installed and every HD channel is working perfectly, except 512.
Has anything changed with their broadcasts? anyone else have this problem?
17 Jun 2024 10:19 AM
Posted by a Superuser, not a Sky employee. Find out moreFor your information GB News is one of the weaker channels broadcasting in the UK, along with CNN & Bloomberg (and possibly Al Jazeera). They use a different a European wide beam rather than the normal UK/ROI transponder.
These channels will likely be one of the first to be affected if your satellite dish is slightly out of alignment which won't be visible to the naked eye so you could see if you can watch those.
16 Jun 2024 10:28 PM
There was a change late last year which makes a slight dish misalignment more likely to cause signal loss in the UK
https://rxtvinfo.com/2023/gb-news-sat-switch-improves-european-reception/
17 Jun 2024 10:14 AM
Oh Well. No great loss.
I just wondered if it was the new box that's just been installed. As wasn't an issue with the old one.
Thanks for the info.
17 Jun 2024 10:52 AM
I have checked and they are all as before. It really is only channel 512.
18 Jun 2024 02:57 PM
GB News is not available today, does anyone know why?
18 Jun 2024 03:02 PM
Posted by a Superuser, not a Sky employee. Find out more@Julie0905 I have merged your post to this existing thread that is discussing the same issue.
18 Jun 2024 05:47 PM
@Julie0905 wrote:GB News is not available today, does anyone know why?
Working fine here, in the middle of a thunderstorm too.
28 Jun 2024 09:11 PM
Clearly, sky have blocked GB News, which is absolutely utterly despicable
28 Jun 2024 09:39 PM
Posted by a Superuser, not a Sky employee. Find out moreGB News has not been blocked and is still available
As the Post now marked as an Answer GB News uses a transponder that is weaker in the UK so any slight mis-alignement wil cause the channel to either pixelate or even for some show as not availble
28 Jun 2024 09:59 PM
@Stellak wrote:Clearly, sky have blocked GB News, which is absolutely utterly despicable
Completely untrue. Though if it were, I'd have a lot more respect for Sky.
28 Jun 2024 11:49 PM - last edited: 28 Jun 2024 11:49 PM
Clearly they haven't, as already mentioned within this thread it's likely your dish is slightly misaligned.
29 Jun 2024 09:29 AM - last edited: 29 Jun 2024 09:36 AM
And simply isn't happening.
The last 'block' was when RT was removed from broadcast across Europe: such things do tend to get noticed and attract wide media attention.
https://www.bbc.co.uk/news/entertainment-arts-60584092
It's worth noting that the transponder change which weakened UK signal was absolutely the choice of the GB News owners to favour (ironically) their audience in mainland Europe .
09 Aug 2024 07:54 AM
GB news is difficult to get and as far as Al Jazeera its accessible . What is the problem please
09 Aug 2024 08:02 AM
Posted by a Superuser, not a Sky employee. Find out moreNo problem. Browse or search to find help, or start a new discussion on Community.
