Discussion topic: GB News Channel Skyq
16 Jun 2024 10:11 PM
Whats happened to channel 512(GBNews)? It seems to have gone SD.
I have just had new Skyq box installed and every HD channel is working perfectly, except 512.
Has anything changed with their broadcasts? anyone else have this problem?
17 Jun 2024 10:19 AM
Posted by a Superuser, not a Sky employee. Find out moreFor your information GB News is one of the weaker channels broadcasting in the UK, along with CNN & Bloomberg (and possibly Al Jazeera). They use a different a European wide beam rather than the normal UK/ROI transponder.
These channels will likely be one of the first to be affected if your satellite dish is slightly out of alignment which won't be visible to the naked eye so you could see if you can watch those.
