Discussion topic: Freeview ok but unable to switch to Sky
This message was authored by: GranndmaChris
After watching Sky channels I switched  the TV off with the remote.  When I switched the TV back on via the remote and  then tried to  switch to  Sky , I just got a blank screen with HDMI in the corner.  Have tried rebooting and updating software (box only recently installed) but nothing has worked.   I would appreciate any advice as not even the virtual assistant could understand me.
Re: Freeview ok but unable to switch to Sky
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
3. Sky Glass & Live (Sky Glass & Live)
4. Sky Stream (Sky Stream)
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Avatar for GranndmaChris
Its a Sky Q box.  Had it about three months
Hi @GranndmaChris   It should work if you switch on the Sky Q box first (not the TV), that should then turn on the TV and put it on the correct HDMI input.
Hi both, thank you for your very prompt replies.  I am very embarassed to say it is now working.  My husband pushed the tv back into its correct position and Sky just came on.  Really don't know how that happened!
