Discussion topic: Forgot sky device pin so cant watch downloaded series on tablet while on holiday
Message posted on 15 Sep 2023 10:23 AM
Cant watch downloaded series on tablet as dont know sky device pin
Message posted on 15 Sep 2023 10:55 AM
Re: Forgot sky device pin so cant watch downloaded series on tablet while on holiday
@Belindawallis50 wrote:Cant watch downloaded series on tablet as dont know sky device pin
Hi @Belindawallis50 maybe this link will help you to reset it
Message posted on 15 Sep 2023 11:35 AM
Try the last four digits of your viewing card.
This number can be found via the remote: Home >>>> Settings >>> System info
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 15 Sep 2023 02:15 PM
Apparently Sky device pin is not the same as Sky tv pin @Doc5907 unless you are connected to the Sky Q box then the pin is the same unless you are out and about then you need to use the Sky device pin.
you can also reset it via Sky Go app from the link
