Discussion topic: For days ive had problems with sky q, it states technical faults, black & blue screen
This message was authored by: Moo+1971
We've turned it off and on many times at the wall. Cant play recordings. Just very poor over the last few days
Re: For days ive had problems with sky q, it states technical faults, black & blue screen
@Moo+1971 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
