Discussion topic: For a few werks i kerp hetting no signal on various channels. Ive had to watch channels on the i pl
This message was authored by: Ec19
My signal has been coming and going for a few weeks, nowi hardly have any channels not affected.
I've tried the on screen help switching off and on again . But it makes no difference.
Re: For a few werks i kerp hetting no signal on various channels. Ive had to watch channels on the
@Ec19
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Ec19
Thanks. Yes I've rang sky snd there saying it's my dish so going to send someone out .
