7
This discussion topic has been answered Discussion topic: Films on Sky Cinema will not download to Sky QBox
This message was authored by: DerekPretty
Every time I try to download a film on Sky Cinema to my Sky Q box, it fails due to a "technical issue and says try again later
Avatar for DerekPretty
This message was authored by: DerekPretty Answer
Re: Films on Sky Cinema will not download to Sky QBox
Went on to the telephone help. After trying lots of different things I was told to do a Hardware reset. Sky Cinema now working but I have lost all of my recordings. We got there in the end but it took 45 minutes on the phone. Thanks for the advice either way.
Hi @DerekPretty Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Sadly I have tried that but without success so far. Thanks
What broadband provider are you on?
Gigaclear
Try swtting your DNS to 1.1.1.1 onth Q box. Sometimes helps with the ad insertion service. Might do no good at all.
No luck yet. Many thanks
