Discussion topic: Fault , sky box not responding to remote other than volume .
This message was authored by: Dawn333
The box is not responding to the remote . I have tried turning off and back on
This message was authored by: hrai
Re: Fault , sky box not responding to remote other than volume .
@Dawn333
I would suggest unpairing the remote from the box and then relinking it.
Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
