Discussion topic: Fan noisy and pausing , rewinding isnt working properly , some recodings say part recd software issu
Message posted on 20 Jun 2024 11:38 AM
The sky box gets very noisy at times (fan) when you pause the programme, it sometimes freezes, watching recordings, the message says part recorded, power cut or software issue , we have to turn everything off to reset it, but it only fixes the problem temporarily
Message posted on 20 Jun 2024 12:17 PM
Re: Fan noisy and pausing , rewinding isnt working properly , some recodings say part recd software
