Discussion topic: Everything is ok except network connection is not working have tried to re connect that's
This message was authored by: sjgrego
I cannot get an sky q program s at all have tried resetting but nothing has changed.
Re: Everything is ok except network connection is not working have tried to re connect that's
Hi @sjgrego
Try a Network Reset found in Q box Home - Settings - Setup - Network.
