Discussion topic: Every time I switch on my sky q multi room box it runs a connection to the main box which is frustr,
Message posted on 15 Oct 2024 01:58 PM
Every time I switch on my sky q multi room box it starts connecting to the main box which can take a few minutes, although it doesn't take long it gets frustrating, should it be doing this every single time? I'd have thought once it's connected it should stay connected?
I've changed the setting on the main box to "always" for internet connection but it hasn't stopped it, both boxes are brand new and our internet speed in is ultra fast broadband at over 75gb
thanks for any advice
Message posted on 15 Oct 2024 02:03 PM
Re: Every time I switch on my sky q multi room box it runs a connection to the main box which is fru
hi @Richfife
Are you leaving it in standby or switching off at the mains ?
If the latter it will always need to re-establish the connection
Message posted on 15 Oct 2024 02:06 PM
Hi @Richfife
Don't know what you mean when you say
I've changed the setting on the main box to "always" for internet connection.
Where is this setting?
You are not switching the mini off at the mains are you?
To refresh connection first try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 15 Oct 2024 05:56 PM
It stays in standby but when i press the in button it reconnects to the main box every time
Message posted on 15 Oct 2024 06:00 PM
We live in a ground floor flat and the router is only about 20ft away from the multi room box, our phones connect fine
