Discussion topic: Ethernet connection from sky q to sky max hub router is different SSID
This message was authored by: JoanneKat
Message posted on 14 Aug 2024 04:10 AM
Over the last couple of days have had lots of issues with my Sky Max Hub, mainly when disabling 5GhZ to connect smart devices and devices not reconnecting when re-enabled but the one I didn't think possible was looking at settings on my Sky Q with its wired connection has a completely different Sky Broadband named than mine
Find out more
Message posted on 14 Aug 2024 07:53 AM
Re: Ethernet connection from sky q to sky max hub router is different SSID
Hi @JoanneKat The name shown on the Sky Q box is meaningless. As long as it works then there is no problem. Mine is showing a router from 5 years ago from a different broadband provider!
