Discussion topic: Error mr204 got fibre fitted on monday
This message was authored by: Donnayqb
Got fibre broadband fitted on monday
my sky box  & mini box keep crashing saying not connected having to reboot both boxes nd hub about 10 times a night sky customer service said they cant find problem
Way fibre been fitted hub wires are stretch there no movement on any off wires sky said that now problem
Re: Error mr204 got fibre fitted on monday
Hi @Donnayqb
You need to carry out Network resets not reboots.
First reset your broadband router.  As you haven't mentioned whether or not it is Sky Fibre I will give both versions.
Once you get the main Q box connected try the following to connect the mini.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
