Discussion topic: Engineer came out on Friday mini not working need a booster
Message posted on 07 Jul 2024 04:01 PM
Engineer came out on Friday sky mini not connecting won't turn on tried to connect ourselves
need engineer back and a sky booster to send WiFi to box
box is not working
Message posted on 07 Jul 2024 05:21 PM
							Re: Engineer came out on Friday mini not working need a booster
box is not working
Hi @Sallyll
Does the mini box turn on with a green led?
if the LED on the right stays amber
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this if you need an Engineer
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
