Discussion topic: E4 and More4 showing no satellite signal.
This message was authored by: Aideen3
channels E4 and More4 saying problem with satellite signal. Had sky engineer out only 4 weeks ago to reset the dish after storms. Had been fine up to a few days ago, no recent adverse weather. Tried turning box off and back on again and removed viewing card and put it back in, no joy.
has this happened to anyone else?
Re: E4 and More4 showing no satellite signal.
@Aideen3
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely another dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you’ll need to contact Sky to book another engineer appointment.
It’s worth noting that:
