Discussion topic: Download on sky signature
This message was authored by: dunnbanjo22
Hi I have sky signature which I believe comes with box sets?
im trying to download an episode of Chicago fire that was interrupted recording due to power failed and it keeps telling me I need to upgrade?
Re: Download on sky signature
@dunnbanjo22
There are a couple of known problems that could be affecting you.
One can be sorted with a simple Setting change :
Do you have the HD add on - if not please try changing the default download preference to SD in
Main Menu -> Settings -> Setup -> Preferences
If you do have the HD add on or the above does not sort you please let us know so we can escalate to SKY
Avatar for dunnbanjo22
Level 0 icon
Thank you I does seem to have helped
