5
This discussion topic has been answered Discussion topic: Does anyone have problems connecting skyq to fire tv
This message was authored by: CW24
Just bought a Fire tv but can't get it to connect to my SkyQ box anyone else had this problem
This message was authored by: Laing1 Answer
Re: Does anyone have problems connecting skyq to fire tv
@CW24 what make and model of tv is it ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for CW24
Toshiba Fire TV
Avatar for CW24
@Laing1
Toshiba Fire TV
This message was authored by: Padam_Padam
@CW24 wrote:
Toshiba Fire TV
Have you connected the Q box using the supplied HDMI cable and selected the appropriate HDMI input using the Toshiba's remote control?
@CW24 wrote:
@Laing1
Toshiba Fire TV
@CW24 a previous customer had the same problem as you and found doing a factory reset on your TV worked for them
My Toshiba fire TV in the guest bedroom worked fine straight out of the box
